registration problems
Beitragvon jules » 20. Februar 2007 22:50
I am having problems trying to register,everytime i load my details it says the code has failed,i have tried this several times putting the code in exactly as it appears,can anyone help,cheers jules :?
Beitragvon Richard aus den NL » 20. Februar 2007 23:36
No worries, Jules, the admins will help you as soon as they see this.
Or send an email to motorang ättt motorang.com (change the ätt by an @)
Or mention it in the "Testforum". It's probably more suited than the guestbook.
Richard from the Netherlands. :grin:
Beitragvon motorang » 21. Februar 2007 11:38
jules,
you can send me an email to above adress with the credentials you want to have in this forum
- user name
- email adress
I can make that account for you and send you the login data via email.
Cheers
Beitragvon jules » 23. Februar 2007 08:28
HI MOTORANG ,I HAVE SENT REGISTRATION DETAILS VIA EMAIL TO YOU,DID YOU GET THEM OK?,IS THERE ANYTHING ELSE YOU REQUIRE,REGARDS
Beitragvon Gast » 23. Februar 2007 14:26
No sir, did not get it :(
Can you try it again?
Email to:
There is not much traffic on that adress in the moment, so I can also check the spam filter there.
Cheers
motorang :D
Gast
Beitragvon jules » 23. Februar 2007 19:18
motorang,have just sent email to the tauentreffen address with my details,let me know if they arrive,many thanks
Beitragvon motorang » 24. Februar 2007 07:44
No, nothing.
Not in my local Emails (I searched them all for "jules" in the body text), and not in the spam filter folder at the provider server.
Strange.
You can write your Email adress here in your answer, and I create that "jules"-account. I see no other way.
Cheers
Beitragvon jules » 24. Februar 2007 15:43
OK MOTORANG IF ITS THE ONLY WAY TO DO THIS THEN HERE GOES, xxxxxxx ,is my email address,good luck with this
motorang: OK, I have got it and deleted it here. Lets try.
Cheers
Zurück zu ~ Gästebuch ~
