Squire-hub: from which car is it?
For non German-speakers. We will try to discuss in your language here, preferrably in English.
Beitragvon Lindi » 6. März 2010 15:39
Hi folks,
spezial question for british sidecar specialists:
Does anybaody know, from wich car or maybe trailer the hub or the whole suspension unit of a Squire Original (~1970) is? I gess, the manufactors didn´t create a special one. First of all I thougt it was from a Mini, but meanwhile I´m not shure anymore. Maybe its from a trailer.
Just bought a Minilite rim, but this does not fit because of non fitting hub-diameters.
Regards
Lindi
Gryße
Dirk
"Die Quellen aller Komik, sind tiefe leidvolle Erfahrungen" F.K.Wächter
Lindi
Re: Squire-hub: from which car is it?
Beitragvon Indiantim » 1. März 2011 12:43
Lindi hat geschrieben:Hi folks,
Regards
Lindi
Hi
The hub will be for a trailer wheel, best option is to get an Engineer to make a new axle to take standard modern hub for the wheel you can get easily. Complete trailer hubs and axles are quite cheap and easy to get (in the UK). Mini 10 inch wheels are not so common any more.
Indiantim
Zurück zu Questions and Answers
