ITS NOT A SIDECAR BUT!!
Beitragvon jules » 11. Oktober 2007 20:00
TODAY AT WORK I FITTED A NICE PAIR OF WASP LEADINGLINK FORKS WHICH I THOUGHT YOU MIGHT LIKE TO SEE,ALSO I TEST RODE THE BLUE ROCKET WHICH I PUT THE FINISHING TOUCHES ON,I HOPE YOU ENJOY
Beitragvon Stephan » 11. Oktober 2007 20:31
Hey Jules, looks nice. But the third weel is on the wrong place :roll:
The Triumph have enough power for this.
Tomorrow I have to go, to a place, bikes and cars dream bad about it
Beitragvon Richard aus den NL » 11. Oktober 2007 20:40
Hey Julian,
Interesting job you have, although trikes are not my cup-a-tea (yet).
Can you tell us why the Blue Rocket doesn’t have this leading link fork? Is it a customer’s wish or will it be installed later?
As you might know, I’m pretty much interested in two-wheel-drive.
For example I can see the black Yam has chain drive and a diff like in chain-driven kit-cars and all the Triumphs have shaft-drive with a differential. Is it Quaife?
Perhaps you can tell a littlebit more about the diffs that are used with both chain and shaft-drive? Would enjoy to read about that. :lol:
Beitragvon jules » 11. Oktober 2007 20:53
THE DIFFS THAT WE USE ARE FORD BASED WITH DIFFERENT INTERNALS FOR THE SHAFT DRIVE BIKES TO GET AS CLOSE AS POSSIBLE TO THE FINAL DRIVE RATIO OF THE BIKE,THE CHAIN AND BELT DRIVE BIKES HAS A DIFF THAT WE MAKE OURSELVES,WE USE QUAIFE BOXES FOR CUSTOMERS WHO REQUIRE A REVERSE BE IT CHAIN OR SHAFT, ON HARLEYS I INSTALL A CHAMPION REVERSE 5 OR 6 SPEED :wink:
Beitragvon Richard aus den NL » 11. Oktober 2007 21:26
jules hat geschrieben:THE DIFFS THAT WE USE ARE FORD BASED
Sierra, I assume.
jules hat geschrieben: ON HARLEYS I INSTALL A CHAMPION REVERSE 5 OR 6 SPEED
I suggested that once for Babi's rig.
Furthermore I have looked once or twice for the chain-to-shaft conversion of the Busa and the Blackbird. They might be interesting for sidecars.
Also the conversion from the left to the right (Quaife) for these type of bikes, I find interesting, but I'm sure you haven't ever looked at it, since you have your chairs on the wrong side of the bike :-D
Beitragvon jules » 11. Oktober 2007 21:35
IM NOT SURE WHAT YOU MEAN WHEN YOU SAY COVERTING FROM LEFT TO RIGHT USING A QUAIFE :roll: ,AND YOU HAVE LOST ME ON CHAIN TO SHAFT ON THE BUSA AND BLACKBIRD :roll: :oops:
Beitragvon Richard aus den NL » 11. Oktober 2007 21:57
Yes, it's getting a bit technical :-D :-D Since I don't have the pictures anymore (or available at the moment) because of my computercrash, we'll talk about that later on (personal) since I don't want to give any ideas away :ironie:
(it's used for motorcyle-engine-based kit-cars, but can in my opinion be used for sidecars too :lol: I will first look for the pics)
Beitragvon leopold » 13. Oktober 2007 21:22
hey Jules,
having nice weather in Wales too?
what is this? special bike for idiots wo like to sit as on the toilet?
Beitragvon Stephan » 13. Oktober 2007 21:30
Nu werd ma nich welmödisch Leopold. Da is noch kein Sitz drauf...
Wie macht man da Koffer dran?
Beitragvon pewibro » 13. Oktober 2007 22:06
Stephan hat geschrieben:... Wie macht man da Koffer dran?
... man denkt sich welche ... :D :D :D
Beitragvon jules » 14. Oktober 2007 10:04
leopold,if thats your idea of how you sit on a toilet then you have a problem,you should be sticking your head down one for all the shit you talk!!!,dont forget to wipe your mouth.
Beitragvon Keusen » 14. Oktober 2007 15:40
@ Jules
ten points
best regards
Eugen j. Keusen
Keusen
Beitragvon leopold » 14. Oktober 2007 16:56
I have had such kind of motorcycle once for repair,
and I have made a real good testdrive with it,
afterwards I felt like sitting on a toilet for a whole day......
thats wath I mean! It's not my kind of bike!
It looks nice, but not for me to drive... :?
Beitragvon Richard aus den NL » 15. Oktober 2007 20:40
jules hat geschrieben:IM NOT SURE WHAT YOU MEAN WHEN YOU SAY COVERTING FROM LEFT TO RIGHT USING A QUAIFE :roll: ,AND YOU HAVE LOST ME ON CHAIN TO SHAFT ON THE BUSA AND BLACKBIRD :roll: :oops:
Sorry Julian, I cannot find the right pictures in my personal file. So you have to do it with some pictures I found in the internet and part of my personal files. This ist not really what I meant, but it must give you an idea.
The part I mean looks similar, to what's been used on the Super-drive of Mobec (http://www.mobec.de) or:
I cannot find it on the Quaife internet-adress anymore. It might be something that's made in co-operation with other manufacturers.
This is a shaft, I must say, that I really like:
Beitragvon jules » 15. Oktober 2007 21:04
THANKS FOR THAT RICHARD,NOW I KNOW WHAT YOU MEANT BY CHAIN TO SHAFT,I ASSUME THAT THE PLATE FITS ONTO THE SPLINES OF THE FRONT SPROCKET,THE QUAIFE IS THE SAME AS WE USE FOR CHAIN DRIVE REVERSE,THE PICTURE OF THE LAST SHAFT LOOKS A BIT TASTY,WHAT WOULD THAT BE USED FOR.
Beitragvon leopold » 17. Oktober 2007 21:53
hey Jules,
yesterday I saw a trike-bike hanging on the trailerhook of a van.
the front wheel was hanging in a kind of triangle, the wheel was off the ground.
and the rearwheels were turning around like wenn you are driving!
but the engine was nut running!
I think that this is a cheap and easy way off transporting a trike,
but is it realy gut for the trike? I mean the engine?
Do you know anything about this?
I didn't have my fotocamera with me, otherweils I have made a picture of it.
greetings Leopold
(the one who don't like to drive a chopper! :wink: )
Beitragvon jules » 17. Oktober 2007 23:03
HI LEOPOLD,I HAVE SEEN THESE THINGS AND THEY ARE LIKE YOU SAY A CHEAP AND EASY WAY TO TOW A TRIKE,I CANT SEE THAT IT WOULD DO ANY DAMAGE TO THE TRIKE AS LONG AS ITS IN NEUTRAL AND THE ROADS THAT IT TRAVELS ISNT TOO ROUGH,CHEERS COCK!!(GRUMPY WELSH/ENGLISH TWAT THAT LIKES TO TRAVEL BUT NOT ON A CHOPPER) :wink:
